This might be another of those pointless threads, but it needs to be done so I can fool with this Century 1.33x convertor. Just so we are on the same page, here's a picture of the thing.
Start by loosening the screw that stops the locking ring from moving too far, this ring then spins off its threads.
Next take out your 0.9mm Allen wrench and loosen the 5 set screws on the rotation limiting collar and pull the collar straight off.
After that remove the two screws and plasic holding the rear lens in place.
After the lens is removed, you can pull the lens housing away from the mount housing from the front.
It is now ready to drill and tap the holes to attach a 77mm to 58mm step down ring, the 58mm almost perfectly centers the ring on the lens, so you could probably drill this on a cheap drill press. Mine will go in my milling machine for better accuracy. 3 or 4 #2-56 screws would probably be enough, I'll do at least 4 in mine.
And thus ends part one of our tale, tune in next time when I drill, tap, countersink, and assemble this modification. I may also add black flocking to prevent reflections off the mount, and will probably paint the edges of the lens black to prevent internal reflections.
