Gomezdaddy
Hello Everybody!
Here's the setup:
Shot Varicam, sent out to P2 Mobile via HDSDI, P2 Mobile recorded (AVC-Intra 100) in 59.94, regardless of the framerate the Varicam was set to.
Imported via log and transfer in FCP, converting to AppleProRes (HQ), 1280 x 720 59.94.
Other than the shots I actually WANT slo-mo (and I do an easy conform in Cinema Tools for those and it looks perfect) I obviously want everything in 23.98.
HERE'S THE PROBLEM:
When I drop some of the shots on my 23.98 timeline, it plays stuttery. Instead of intelligently pulling down 23.98 fps out of the 59.94, FCP seems to pull down duplicate frames. (Only on some of the shots, which doesn't make sense.)
I can't get CinemaTools to simply conform it because it actually HAS all 59.94 frames per second. Conforming to 23.98 just makes it slo mo. Maybe there's a tool I don't understand there?
There are a couple workarounds---convert to DVCPROHD and then use the frame converter. (It only works on DVCPROHD not prores.) Or drop in aftereffects, which does a perfect pulldown. Problem is, it's for a film, and I can't afford to lose quality with all the rendering back and forth.
Any ideas?
THANKS!!!
Here's the setup:
HERE'S THE PROBLEM:
Any ideas?
THANKS!!!
