markcurtisp
Can someone explain to me what is is?
Here is a passage I found online,
Whatever your setup, it’s best to avoid (as far as possible) concatenation errors, one of the scourges of video production
. Concatenation errors are produced because every codec leaves its mark on the media in the form of artifacts which the codec designers hope will be either unnoticeable or unobjectionable. If the media is rendered into a different codec, those artifacts will be rendered too, and may become more obvious as a result. Also, the new codec will have added its own characteristic artifacts, which will be quietly waiting to potentially show themselves at the next stage of compression the media goes through, perhaps when a Blu-Ray disc is made after editing is complete.
So what should i be looking for when doing an error assessment?
. Concatenation errors are produced because every codec leaves its mark on the media in the form of artifacts which the codec designers hope will be either unnoticeable or unobjectionable. If the media is rendered into a different codec, those artifacts will be rendered too, and may become more obvious as a result. Also, the new codec will have added its own characteristic artifacts, which will be quietly waiting to potentially show themselves at the next stage of compression the media goes through, perhaps when a Blu-Ray disc is made after editing is complete. So what should i be looking for when doing an error assessment?
