Compressor
CookFX Productions
Is there ways to combine internet compression settings to get better quality Because Im having a hard time getting a nice look. And i hope its not my shots because first my memory and now my eyes, dude. Really Im really getting good burns, but bad uploads.
Not sure what you mean by "combine internet compression settings".
From Compressor, I find these settings work best: exporting 640x360, Quicktime H.264, 900kbps, key frame every 10 seconds (240 frames on 24p footage) and audio at 96kbps in mono. Most important for the web is progressive footage - deinterlace if you didn't shoot in progressive.
The reality is that your footage could be making bad compression. The more noise and movement there is, the harder the compressor has to work to make a small, HQ file. Also, file size is directly related to quality. Smaller sizes means lower quality.
One last point, HD footage down rezzed to WEB resolutions looks much better (especially the titles) than starting off with SD footage.
Jason
what i meant is there a way to compress the audio then the video and combine the files for the internet. I have been using the same setting for the net but I never thought of changing the frame size, and im having problems locating that in the menu.
