Compressor stretching text
sbryan
I have some two-line text I added in FCP along the lines of: Jeff B. / Customer
The text exports correctly in MPEG-2, but for some reason when I export at 640x360 for YouTube 16:9, the text gets stretched vertically.
The image itself is fine! It comes from 16:9 source material.
Confused on this one.
Thanks for your help.
it's an annoying bug. the only way i've been able to get around it is to export the cut as a full res quicktime in its native codec. then, import that file into compressor to make the 640x360 file from that.
That does the trick. Thanks.
There's a problem introduced in that extra step of exporting the sequence to a QT file before moving to Compressor:
There's a slim 1px line of video noise across the top which appears green on my screen.
Any advice on how to eliminate or mitigate its presence? I'm picky, so I notice it. Not sure how noticeable it is to others.
