Ugh,
Dvx100 60i squeeze SD export to compressor from FCP. I used HD settings to compress because I thought that would compress for 16:9 to then go to DVD St Pro. When I try to import to DVD St Pro "Incompatible Import" pops up for the video file.
Should I not have chose HD settings for Squeeze project? What settings should I have used for 16:9 output to DVD St Pro?
Still trying to wrap my head around Compressor & DVD St Pro & FCP & ....
My settings in compressor are as follows:
This is the summary for mpeg 2 video file settings:
Name: MPEG-2 6.2Mbps 2-pass
Description:
File Extension: m2v
Estimated file size: 143.78 MB
Type: MPEG-2 video elementary stream
Usage:HD DVD
Video Encoder
Format: M2V
Width and Height: Automatic
Selected: 1440 x 1080
Pixel aspect ratio: HDV 1080i (16:9)
Crop: None
Padding: None
Frame rate: (100% of source)
Selected: 29.97
Frame Controls: Automatically selected: Off
Start timecode from source
Aspect ratio: 16:9
Field dominance: Automatic:
Selected Bottom first
Average data rate: 6.2 (Mbps)
2 Pass VBR enabled
Maximum data rate: 7.7 (Mbps)
High quality
Best motion estimation
Closed GOP Size: 15, Structure: IBBP
DVD Studio Pro meta-data enabled
Chapter markers only
The A/V Attributes for the copy:
Video:
Encoded bounds: 720x480
Display bounds: 640x480
Pixel Aspect ratio: NTSC CCIR 60i/DV
Frame rate: 29.97
Thanks for any help.
Description:
File Extension: m2v
Usage:HD DVD
Video Encoder
Format: M2V
Crop: None
Padding: None
Selected: 29.97
Aspect ratio: 16:9
2 Pass VBR enabled
High quality
Video:
Frame rate: 29.97
