Compressor - Exporting MPEG-2 For DVDSP
I have a 50 minute concert I shot with 12 angles, and I am burning a master to duplicate. In FCP7 I sent the sequence to Compressor, and I selected the DVD 90 min - best quality preset. But when I put it into DVDSP and previewed the DVD, no audio played through. I also tried playing the .m2v file through VLC player and still no luck on the audio. I tried re-exporting with the Dolby 2.0 setting right below the previous preset and it gave me the same exact file as before. Am I totally missing something here, or is there a way to join a separate audio file with a video track in DVDSP? Thanks in advance!
m2v is an elementary video stream (no audio). It should have also spit out an AC3 file, which is your audio. Dragging this into the DVDSP timeline should be a perfect fit, and work once played.
In compressor, if you drag the preset folder it will have the m2v and audio file. You should end up with 2 files when it's done, one video, one audio. Drag both of those onto the track in DVDSP and you should be good to go.
