I have tried to use compressor as a converter PAL to NTSC. But when I import it then in FCP I see that it is NTSC but with 25 fps, strange isn't it?
Anybody who can help?
thanks
Neither FCP nor Compressor is a true standards conversion. You have to change the fps (nicely) and resize slightly. There may be soem plugins for FCP that would help.
format conversion works fine in Compressor 2 and the quality is amazing. Check the settings, make your own setting for NTSC and make sure everything is right. I did it that way and it worked fine .... but expect to wait for your results ...
