Compression artifact in rendered text
hellboy80
It's a matter of either de-interlacing, or codec. WMP and VLC don't use the same codec pack, so you can't expect the same decoding, or bugs.
Also, the DV codec should only be used for going back to tape, or for archiving, not as end-viewing codec. As long as your Vegas decodes it correctly, you are fine.
Ok then, just export it in DV AVI, and let them use it. Vegas exports the correct DV AVI, so as long as your project properties are set correctly, you have nothing to fear.
