I've been given some gl2 footage to cut into a documentary i am filming using dvx in progressive f5 mode (default). I am rubbish at colour correcting & levels etc & am trying to get the gl2 footage (which i have made progressive in after effects) to fit in with the dvx stuff as best i can. I know it will never look exactly the same & each scene may need different levels (all ouside natural light footage) but has anyone had any luck trying to match these cameras & if so could you let me into your secret. Im also aware that after effects is probably better for colour correcting than prem pro so if you have a solution that way then all the better, tho prem pro would be quicker & easier. i've got after effects 6.5 pro & prem pro 1.5 & cs3. Many thanks if anyone can help
Sorry for the double post but i thought i need to ask the question in both premiere & after effects. Mods you may delete one if you think i'm being too cheeky
