Hi
Trying to implement Color management in the PPro to AE workflow. I understand the concept of color space and how to enable it in your Project Settings.
1 What profile should you assign typical DSLR footage (thru interpret footage)?
2 For a PPro to AE Dynamic link workflow, what OUTPUT profile should you use in the (After Effects)Output Module Settings if your end result is to be rendered back in Premiere Pro and output for the web or desktop only?
I notice that not all output formats support embedded profiles and I am also making the assumption that Premiere Pro will recognize the appropriate embedded profile as well.
