Color crashes on openning
dr.vaknin
Hi all,
Yesterday I have finished working on 90 min sequence in Color.
I sent it all to be rendered and this morning when I got to the computer I found out it didn't finish rendering.
my guess is due to lake of space in the local hard drive.
I also had an internet problem so I closed the programs that were opened and restarted the computer.
since then, the program will open and work with any project BUT the project I was working on.
when I try to open my project the software closes immediately.
console Messages says:
10/4/11 12:56:54 PM com.apple.launchd[130] ([0x0-0x65065].com.apple.color[877]) Exited abnormally: Abort trap
10/4/11 12:58:54 PM com.apple.coreservicesd[84] NOTE: Using non-mach-based version of client -> server communication, via direct function calls.
10/4/11 12:58:58 PM [0x0-0x6b06b].com.apple.color[949] terminate called after throwing an instance of 'common::exception'
10/4/11 12:59:01 PM com.apple.launchd[130] ([0x0-0x6b06b].com.apple.color[949]) Exited abnormally: Abort trap
10/4/11 12:59:01 PM com.apple.coreservicesd[84] NOTE: Using non-mach-based version of client -> server communication, via direct function calls.
10/4/11 12:59:11 PM [0x0-0x6d06d].com.apple.color[961] terminate called after throwing an instance of 'common::exception'
10/4/11 12:59:14 PM com.apple.launchd[130] ([0x0-0x6d06d].com.apple.color[961]) Exited abnormally: Abort trap
10/4/11 1:00:00 PM com.apple.launchd[1] (0x1013b0.cron[968]) Could not setup Mach task special port 9: (os/kern) no access
10/4/11 1:00:22 PM [0x0-0x6e06e].Color[964] terminate called after throwing an instance of 'common::exception'
my specs:
Mac Pro 3.1
2 X 3 GHz Quad core Intel Xeon
16 GB 800 GHz DDR2
Mac OS 10.5.8
My deepest blessing to the one that saves me.
I have tried clearing space from the local H.D
tried to configure the render location to a storage device with out luck
tried restarting the computer several times
I don't know what els to do...
I had similar issues but it was because I ran out of disk space. Have you tired renaming that file that causes the crash?
