color correction
Moseph
if I create a color correction for one particular clip, is there a way i can apply the same exact color correction settings to multiple clips?
you can save your settings in your bin by dragging the filter in the bin and then you can rename it. Or you can do Apple C on the clip you just color corrected and then do select all the other clips that you want to use this color correct on an then do Alt V and select filters and click OK.
