Color correction?
jinks
Juust curious if there are any color correction plugins for vegas e.g colorista? other than the ones built in the NLE itself.
I think MB is the best you can do. There is stuff from VASST, but it uses Vegas' built in filters in a chain.
Although not great, I much prefer CCing/Grading in Vegas as opposed to AE.
Thanks Horsefilms, I just dowloaded that plugin and it actually does wonders. I'm still hoping there are more options out there for vegas but thanks a bunch for that link!
Just FYI Eugenia,
In response to your post under your blog, you can add more points to the curve (double click on it anywhere) and if you right-click on a point, select "unlock tangent" and you can move it anywhere you like.
I see. I am still not able to move the black bottom point to the left though, while I can move it up. On photoshop the curves can be moved in 2 axis.
Hi ZAZA,nice u found it!I know the plugin cause i 've already installed.I use it just for the correction of a wrong WHite balancement. I was reading in another post for other tricksin the previous page about the ù"That 6way cc",how does it work?
thank you
I use Magic Bullet Looks, for everything else I use "Color Curves" that comes with Vegas, does a great job at correcting color.
