Color Correction HVX200 wrong white balance preset
jrp
Hi
Here's the situation.
I shot my film with the HVX200 white balance presets (3200k for indors and 5600k for outdoors). But one outdoors shot, accidentally got shot with the 3200k preset.
Now, I've tried ti fit it using the cc tools in both AE and Premiere, but I'm not skilled enough to get it right; to gae ti to match the other footage. (tried both the white balance eyedropper, and to manually move the color wheel.)
The thing is, as it's a correction from 3200k to 5600k, I'm sure there must be a by the numbers way to fit that shot; to fix any shot that has that problem, since it's a constant white balance shift (Something like: move the gamma 1.23 to the left, or something).
Any help would be deeply apreciated.
Well, it's not that simple. This would be true if you're recording in a RAW format, but since there's compression involved some of the original color information has been lost and trying to get it back won't result in the exact same shot. With that said, you should post a grab of each of the preset and people here can give it a shot.
A fun activity for the weekwnd!
Thanks Huy Vu for your suggestion. Here are the grabs so people here can give it a shot.:)
This 3 are from the same sequence, and are subsequent shots. the one in the middle was shot with the 3200k white balance preset, while the other 2 (as the rest of the scene) with the 5600k preset.
This next one is the one to fix.
The following 2, again, are of subsequent shots, and the firts one is with 5600k (as the rest of the scene) and the second one was shot with the 3200k white balance preset, and is the one to fix.
Thanks guys in advance.:dankk2:
