DVXSanDiego
Firstly, thanks for any advice people give on this.
We're in the final stages of a feature project, and I spent some time last night color correcting (mild stuff, slight adjustment to curves, B/W filter to desaturate, slight adjustment with secondary color coorector) all done directly to DVCPro HD files via Raylight plugin in Vegas Pro 8 at 32-bit.
It looks good, but there are some slight artifacting problems, I'm assuming because the adjustments are happening in such a compressed space. I've read in Stu Maschwitz's DV Rebel book that the best post workflow is to output all untouched files to an image sequence and do all the work in After Effects. We have access to AE but given our unfamiliarity with the program and the simple work we plan on doing, it seems to be overkill. And now that Vegas does processing in a 32-bit space, we would like to do all the post work in Vegas.
So this leads to my real question: What is the best workflow for getting our final edits into a less compressed space to do CC in? Render our to Cineform, re-cut at the edits and CC? Render out to image sequence? What do you all do? Any personal examples, examples of footage, etc., are welcome.
And one note: this footage will be seen in theaters, at least at festivals, possible with a small theatrical run. It has to look as clean as possible...
