Chadfish
Hi
I have a long, 2 cam show I shot. I color corrected the original footage so the 2 angles match pretty closely. Then I burned each angle to a new file so they are exactly the same length, rather than being a collection of shots. Upon editing the multiclip I am noticing that one angle could use a slight color adjustment, however I am 2/3 through the show as far as cutting back & forth goes. Is there a way to apply a filter one angle and have it show up in all the cuts?
I can put a 3-way color correcter on one of the cuts, or on the whole thing, but I don't want to go back and apply the filter to every other cut in a 2 hr show. It seems that if I double click the source file of one of the clips in the browser - it will appear in the viewer. Usually you can apply a filter to that and it would apply to any clip brought out of the viewer. That's not working with multi clips. I can drop a filter in one of the "2 up" clips showing as I edit the multicam, but that only applies to that particular in-out of that one cut. So I'm stumped there.
One question I have is: Can I re-render one of my angles, and have it apply to the multi clip, and all the cuts? It takes 5 hours to render one camera angel, so I don't want to try it and have it not work, or ruin my already made cuts.
Any help would be appreciated.
