slimjimmed
I am color correcting a 1920x1080 30p documentary feature on a Macbook Pro > MXO2 mini > Dell U2410
I am using the sRGB setting on the Dell's OSD and have turned the brightness down to a suitable level. However, I think that my color space is leaning to the yellow/green.
My skintones seems a little yellow/green when I correct them onto the vectorscope i-line in Color. (They look normal on the monitor when they are above the i-line)
Can somebody help me in suggesting a way to make sure that my hue's on my Dell are more trustworthy? Should I rent a broadcast monitor and run it through the Component or RGB out at the same time as my HDMI Dell signal, and adjust the colors by hand to match an SD referencemonitor?
I also don't know if my color space would be different on an SD reference monitor,in comparison with my HD signal on the Dell? (would I be making matters worse by matching the HDMI HD signal's colors to a Component SD signal?)
I live on Portland, OR and am having a hard time finding a place to rent a tool that will help me dial in my color so that I can have some piece of mind....
