paulears
One for the experts here. I've had a Coles Lip mic for quite a while, and it's had fairly hard use, but worked very well. Removing the front guard to give it a clean, I thought that as these get a bit unpleasant, maybe now was the time to dismantle the mic itself and give that a clean. I took off the lip guard assembly, and removed the rounded edged rectangular front grill. Inside were two back to back thin fine mesh screens and I split these up and took them out. I also removed the front and rear hemispheres, but inside, the condition was spotless, and I left the pinkish gauze in place. The two mesh filters when I tried to blow through seemed blocked, so I gently soaked them in some biological cleaner, took them out, blew through them (with little difference, I noted) and then re-assembled. When I plugged it in, the sound from the usual front position was very thin and weedy. The rear and sides have much 'fatter' sound. The normal position was always flatter - on these mics, rather like using an omni mic up close instead of a cardioid - but now the 'flat' has become 'thin' and also very quiet. Speaking into the rear of the mic produces more level than the front, so I also seem to have lost much of the isolation I used to have.
The only think I can think of is that the two back-to-back filters have (had) aligned holes, and my re-assembly has offset them enough to effectively block the sound getting through.
Has anyone experienced this - these filters could have been factory sealed together, and I just pulled them apart thinking they were just stuck together by spit? If I use the filter paper between the metal shield and the removable lip guard plate, as I usually do for hygiene, the sound is even more useless.
I'm stuck - I've no idea what I've done. The internals have not been touched at all - just the filters.
