Clips in sequences being "laggy"
neweditor
I'm currently editing 4k ProRes 422 LT clips shot w/ A7S + Shogun combo and 4k MPEG4 XAVCS clips shot w/ RX100 in Premiere. The setting it gave me to closely match ProRes is DNxHR UHD. Now, when I'm editing the ProRes 422 LT clips there's no problem. The previews instantly come up, no lag time, perfect responsiveness. When I'm editing the MPEG 4 XAVCS in the same timeline with the same settings, it "lags" quite a bit. As I scrub through, it takes 3/4th of a second every time I scrub for the video to match the playhead, and just general lagginess. Is there anything I can do to remedy this situation? Edit the RX100 clips in a separate timeline with separate settings? Any recommendations?
My system:
i7 5960X Processor 8x Cores
64GB (8x8) DDR4 2800
GTX 980Ti - 6GB Superclocked
ASUS X99 Deluxe/U3.1 MB
500 GB Samsung 850 EVO SSD Boot Drive
Serial ATA 1TB SSD Preview Cache
8TB (2x 4TB HD) Raid 0 Thunderbolt Media Drive
Thanks very much in advance.
Prores runs like the wind on my dual Xeon workstation. I've tried to find the limits on the number of streams, so I put together a project with 5 UHD Prores streams from my FS7-> Shogun--one full screen, the other four scaled and panning across the screen in a circular motion. All clips S-Log3 and have LUTs applied and some sharpen and color adjustments in Lumetri. All plays smoothly at about 35% CPU utilization.
Rendering HD 1080P for internet and Blu-ray, I use NVENC plug in which uses the 3072 cores on my Titan X GPU. My last 4 camera XDCam MPEG35 multicam concert shoot was 90 minutes long and rendered to a MP4 in about five minutes.
The weak spot is XAVC. The system can almost reliably handle one XAVC stream, either 4K or HD @24FPS, but more than one stream it starts to drop frames. Forget about 60P. No matter if it's 4K or HD, the frame rate is too fast to decode XAVC on a dual Xeon. Need a hardware decoder to work with XAVC multiple streams. Prores does not. Easy to edit and no sweat.
AVC codecs in general are very CPU intensive to decode in an NLE. NLE's decode and buffer whole GOP's (Groups of Pictures) at a time and buffer to ram for editing. An all i-frame codec like Prores or Cineform, or even AVC i-frame takes a lot less machine overhead than interframe long GOP codecs.
