working with several hundred files and about 10 of them can't be read: "Clip frame rate (69940) is not that same as project frame rate (23976). Do I have to make a new project with a different frame rate and export? Solutions? Thank you.
The clips came from the original harddrive that contained the entire project.
I created a new test project with a 720/59.95 setting and it read most of the clips. I suspect the camera op accidentally adjusted the setting. So I transcoded and exported the clips and imported them into my Master project as .mov files
Am I setting myself up for trouble down the road mixing MXFs and .mov files?
