(I'm just starting to edit again this week after a few weeks of downtime. I can't recall when exactly I upgraded to 6.0.4, so it's possible it's an error for the version itself.)
Basically I have two tracks of video and I am cutting back and forth between the two, often with a cross dissolve transition. Whenever I add the transition to the end of the clip on Track 2 and render it for playback, both clips playback with a weird jump, as if once the transition occurs they each want to sync up with the original end/start of the clip on the timeline. I then perform a full render, which fixes the jumping effect, but now the clip on Track 1 appears to have been slipped (the beginning of the clip seems to be several seconds later than I originally had it set to begin). Any ideas what might be going on here? I've restarted both FCP and my computer. I've thought about downgrading to 6.0.3 (which may be necessary), but I have a few other 6.0.4 projects (none that used transitions) that I wouldn't be able to open (unless that's just a 5 vs. 6 issue).
