I recently received a couple B+W UV's and a new 77mm B+W Kaesemann CPol from Amazon. I spent almost an hour cleaning the Kaesemann. It had some smudges around the edge out of the box and no matter what I tried I kept seeing this light haze or smutz on the glass. Similar but not so dramatic problem with the UV's. I finally got it to the point where it was ok to the naked eye under a lamp and left it. Am I obsessing?
The glass looks real good under an incandescent bulb held to reflect. But I then examine it with an LED flashlight at an angle which brings out every imperfection. I swear I even see miniscule bubbles in the glass sometimes on the UVs. But always this "haze"....rub marks from where I pushed the paper around.
So, what am I doing to clean you ask.
I start with a good blow from my rocket and brush from a Giotto lens brush. Then I try dry Tiffen lens paper. At this point I see some, apparently, oily smudges and pull out the Zeiss lens cleaning fluid. I spray a hint of the fluid on clean lens paper and clean the glass. This leaves a light haze which I then obsess over with piece after piece of dry lens paper. Giving up on that I try my microfiber cloth which seems to do a better job on the haze but I prefer a disposable option like the paper. Ultimately there seems to be some haze constantly being pushed around that I can "polish" almost clear with the microfiber but not remove.
I thought it was perhaps the coating, perhaps softened by the Zeiss cleaner but the MRC coating on the B+W lenses is supposed to be harder than glass so I doubt that is it.
Are they just filthy from the factory? Am I trying for too much optical perfection?
Help and comments very much appreciated. And forgive me if this is the wrong place for this post, but it looked like perhaps the right place.
Thanks,
Matt
Thanks,
Matt
