STORYTELLER32
Clayton! Oh wizard of FCP! Please help!
When I went to output my edited timeline to my mini-dv tape (on my cannon elura) I was in shock to see my footage suddenly having a "video look" to it. It no longer had the film like movement quality that 24 fps gives you. Looks more like Canon XL1 footage instead of DVX-100.
I'm wondering if this has to do with the settings I captured the footage at? Here's what my captured and editing sequence settings are prior to print to tape:
Captured at DV NTSC 48 khz Anamorphic
Editing timebase 29.97 field dominance lower (even)
compressor: dv/dvcpro - NTSC
Now mind you, it looks like 24 fps in FCP4 and only looks like video footage when I output to tape.
I tried to fix it by creating a new sequence timeline with either 24 or 23.98 as my sequence preset settings and copying the original sequence and pasting it there. I had to render the whole sequence again, but in the end, it only gave me choppy footage that wouldn't even record when I tried to print it to tape.
Is it even possible to alter the settings in a new sequence timeline, copy my sequence and paste it into that timeline and avoid recapturing my source footage to my hard drive? Or do I need to start from scratch?? If it is possible, PLEASE detail what I need to do.
Forever your slave if you can help...
Storyteller32
Storyteller32
