Clarity and Vibrance powergrade for Davinci Resolve
JoeThePro
I have created a Davinci Resolve powergrade that simulates Adobe Lightroom's "Clarity" and "Vibrance" effects. Its not perfect, but it is very close. Here's the first version, I will update the powergrade if I find a way to improve it. When you append the node graph, it gets a little sloppy, but its managable.
Separate nodes at bottom for:
-Saturation (why not)
-Vibrance (adjust saturation slider)
-Clarity (adjust output gain in key area)
Get it here: http://s000.tinyupload.com/?file_id=84027486602946538525
..or here: View attachment CLARITY_VIBRANCE_v1.zip
A better clarity version will be released soon. I realized some mistakes, and the coming version will actually be a true local contrast adjustment.
Im happy to finally release version 2 of the clarity and vibrance simulation powergrade. I did some research and discovered that Lightroom's vibrance did more than I initially thought, so I replicated its behavior as best I could In Resolve. I also adjusted the clarity simulation to be a more simple solution which still works fairly well.
- Adjust the OUTPUT GAIN slider in the key area for the VIBRANCE and CLARITY nodes to control the intensity.
- Download the powergrade at: http://s000.tinyupload.com/?file_id=39826648446891047528
Hi Joe,
I'm curious if your power grade for Clarity & Vibrance is still working in the newer versions of DaVinci Resolve and if you could share it with the community again.
BUMP
