Dennis Wood
DVXuser Sponsor
Barry, what's your suggestion with regard to a decent light meter? I'll run some tests on the HV20 and XH-A1 cams here to correlate IRE and f stops. I would guess the 8 bit limitation will limit an HDV/DV cam to 5 stops, with an extra stop dynamic thrown in for knee and stretch at the high/low end of the curve. Based on my research, I'd also assume the predictions will be easiest in the 40-60 IRE range? I was using this as a base: http://www.24pdigitalcinema.com/cinegamma.pdf
