Amadou
Carbonite Member
When exporting to Cineform from the Premiere Timeline, we noticed that all exported clips are clipped on the superwhites (This happens in all export settings). Anything above 100% gets clipped. This means information gets lost on the brightly exposed regions. We tested exporting in other formats including H264 and none of them have the same clipping problem. THIS IS A MAJOR PROBLEM FOR COLOUR CORRECTION. You can't recover the white regions. All the info gets lost. Cineform is therefore the problem here. Has anybody else had to face this problem? How can Cineform be considered professional if you can't use it to export properly? I contacted them and am still waiting for a response.
Meanwhile since I work on PC, I can't export in Pro-Res. Is H264 good enough to do the back and forth post production workflow? I can't use Cineform to do any sort of colour correcting or even post production sub contracting until the clipping issue is solved.
I'm surprised this never came up before. What lossless codec could I use as an alternative which can go back and forth between platforms?
