Cineform & CS3 PROBLEMS
bustak
Hello,
I was using the Cineform Aspect HD 2-week trial for Premiere CS3. After a week & a half I decided to un-install it. Once I did that, I'm unable to import any HD footage. So when I try to import a m2t file I get a Time.cpp-105 error:
I even un-installed, then re-installed Premiere & I still get the same thing! 2 things I should mention, when I launch Premiere I get a box saying the Cineform trial has expired:
After I click OK, to not enter a serial #, there's still a option to use the Cineform settings:
Has anyone else have this problem after they un-intsalled a Cineform product? Any help you could provide is MUCH appreciated, as it stands I can't work on HD footage in Premiere @ all. :(
Thank you!
We have not heard of this issue. The time.cpp is an Adobe Error, so you may need to contact Adobe is the problem continues. Aspect HD doesn't install (or uninstall) any MPEG handling components, we are strickly AVI or MOV based. However it does seem that some component didn't completely uninstall.
Here are the directories and files that should have been removed with the uninstall.
These are the plug-ins:
C:\Program Files\Adobe\Adobe Premiere Pro CS3\Plug-ins\en_US\CineForm
The presets:
C:\Program Files\Adobe\Adobe Premiere Pro CS3\Settings\en_US\CineForm
And this file is the editing mode:
C:\Program Files\Adobe\Adobe Premiere Pro CS3\Plug-ins\en_US\Editing Modes\CineForm Editing Modes.xml
Manual direct these to clean up your folders.
David, you are the man!
I posted the same question on another forum! I'll go over there & paste your reply!
Thank you VERY much!
