Dan Hudgins
Any word on the fan noise?
As you may know the KineRAW-S8p (tm) does not have a fan, and without a HDD in it it is silent, other than the autoslate beep.
The KineRAW-S35 (tm) I have here just has one speed fan and does not get very hot with that running, I've had it on for hours at at time and it gets warm on the outside but not too hot to put my hand on. I can hear the fan but its a low frequency sound as I think the fan is running at reduced RPM or something. If you had the mic on the camera it might pick up some sound indoors even with an isolation mount as I can hear the murrrrr sound if I'm within maybe 3 feet of the vents. Outdoors with the mic more than 4 feet away I don't think it would be able to be picked out of the background sound. I have a db meter I might be able to get a measurement?
My RadioShack Sound Level Meter reads -10 on its scale set to "A" weighting Slow response, 60db scale at about 2 to 3 inches (about 50 to 75mm) from the air vents, I cannot read a signal on the top of control side at that same distance because -10db is near the analog meter's left post.
They told me that Epic (tm) makes more noise, anyone have one they can measure the air vents and other angles at 2 to 3 inches?
I guess its less than 50db absolute close to the case, you can work out the inverse square law to get the sound level at some distance. My computer fan reads much higher, at the same distance my computer reads 66db fan noise.
These are not official values of the production cameras, but if you come over with a similar meter you might read a similar level.
The noise level in the house tonight is probably over 40db absolute so even if I had a more sensitive meter I could not read the sound at 4 feet from the camera, probably. It does not sound like a hair dryer. Alvin did mention it when we were shooting the other day, maybe someone asked him about it.
If you can still get that same meter at RadioShack (tm) and you have access to Epic (tm), RED ONE (tm), and Alexa (tm) you can put it 75mm away and see if the needle gets above -10 on the 60 scale with A weighting and Slow response. Then report back and we can tell something, or if you want to stop by with your camera I can measure it maybe?
The point to take away is that at about 6 inches I don't think my meter can measure the sound(?) its underrange.
I got a photo from the trade show, a company called Movcam (tm) in China has made some accessories to fit the camera,
Quote: [Movcam made three special parts for KineRAW-S35: handgrip, riser and bridge plate. They seems very good.]
I have attached an edited copy of the photo they sent to me,
Here is the Movcam web site, they seem to be in the booth next to Kinefinity (tm) (booth 2B222) and Movcam in booth 2A222?
http://www.movcam.com/
