China balls!!!!
that socket will allow for the daylight flouro lamps and everything?
and is that socket going to work with the specific ball I linked??
yep, they'll work together. the only issue you would have with a flouro lamps is if you have it on a dimmer. the china ball has a thin metal portion that holds it in an expanded state like you see in the picture. that rod system also has a place at the center of the hole where the cord of the socket is tucked/woven to hold the flouro lamp hanging inside the center of the globe.
