Does anyone with more knowledge than me think these might be useful? possibly for a ring-lite or
something?
http://www.mainlandmart.com/ledmart.html
something?
Cool Lights said:Could be. The first ones, that work on 12v DC are interesting--this allows you to control with a dimmer easier, perhaps hook up a battery easier and also is more of a guard against flicker. But it also depends upon the quality of the LEDS/brightness and the CRI of the light they put out.
I can find these things all over china pretty inexpensively but I didn't think to offer them because the damn housings are so heavy and don't seem so suited for video production needs. What they have to do to get them to work underwater seems like it makes it an overkill fixture.
In addition, I don't like the glass on the front--allows heat to build up inside and probably contributes to shortening the life of the LEDs. I think an LED spot for inside use, with no lens, the lightest weight housing and 12v operation would be more interesting. But if you try one of these out, let us know.
PDX_DVX said:The LR-A120W looks interesting, you could probably remove the plastic support pieces on the inside and adapt it as a ring light somehow.
Down toward the bottom, the QL-24W looks pretty cool as well. Might be good for car shooting or something
That's my point exactly--the quality of the light. Finding a true white one is a real challenge. I visited an LED factory recently and watched the process. Basically it involves manufacturing a run of what you hope will be a certain color but they put each LED through a testing machine which also sorts them by color temperature into different bins. No doubt, the white ones are more valuable and the bluer ones more plentiful and thus more cheap.PDX_DVX said:Someday when time and money allows I'll pick some of these up and do some experimentation. I'll keep you posted! I have found that a lot of cheapo LED's that claim they are "white" tend to be waaaaay blue. Anyhow, I'll try them out.
Good eye Carlos, I didn't catch that. 12VAC seems strange to me too. You don't see that often. I wonder if its a misprint. The 144 led one caught my attention the most I guess. I tend to like the ones with more LEDs. But if it's AC of any voltage I wouldn't buy it. Makes dimming a harder or impossible challenge. And you always have the possibility of flicker too.Carlos_E._Martinez said:Which models are the ones you find interesting? The LED72 and LED144?
It's strange they spec them as 12 VAC, which I can't really say if it's watts or 12V AC.
The smaller type looks like aluminium cased, and it's probably heavier. The other is ABS, so it should be lighter. It would be good if they did specify the weight.
I don't think heat might be much of a problem, being LEDs. The ABS' front round glass seems to be detachable with six screws, so a frost glass or gel might be used for correction or effect.
The main problem for me, is how to attach it to the camera, as well as getting some barndoors to use with them. Certainly a dimmer would be great to have.
Cool Lights said:That's my point exactly--the quality of the light. Finding a true white one is a real challenge. I visited an LED factory recently and watched the process. Basically it involves manufacturing a run of what you hope will be a certain color but they put each LED through a testing machine which also sorts them by color temperature into different bins. No doubt, the white ones are more valuable and the bluer ones more plentiful and thus more cheap.
Cool Lights said:The 144 led one caught my attention the most I guess. I tend to like the ones with more LEDs.
On the heat. You'd be surprised how hot they get once packaged in a sealed aluminum or plastic container with a glass lens.
A plastic, open faced housing seems like it would be the best to me. With the thinest, lightest barndoors you can dream up. No need for mirroring on a barndoor for an oncamera unit so just black/plain barndoors.
Also, I wonder how important a yoke would really be in an oncamera light. Maybe a yoke should be an option for when you want to put it on a stand--then weight is no problem at all.
Cool Lights said:On your question about voltage: they're probably 12vdc as that's the most common underneath all the different layers they put on these things.
I'm not so much a fan of those luxeon ones. Talk about heat output and sucking up battery power. I think the arrays of several rows of smaller LEDs have the most merit for a softlight type on camera fixture.
