Ralph Oshiro
Probably the most versatile mini dolly set-up I could wish for would be a small-surface (1' x 1') base, attached to a set of wheels that could hold a rail system captive. For the "track," suppose you took two cylindrical pieces of metal about 0.5"-1" in diameter and created various pairs of these "rails" in varying lengths, say, 3', 4', 5', 6', etc. Nothing too long, since the metal would flex. At the ends of the rails, secure them with a crossmember so that you have a "rail section." This "section" would never have to be assembled or "set-up." You could just lay this "mini-rail" section down, or C-clamp it across two ladders, or mafer-clamp it to whatever.
The dolly wheels would have to be designed such that it has a set of wheels both above and below the track (so that the track would be "captive") so that the platform could be inverted, if needed. One wheel set would need to "release" to be able to "clamp-on" to the rail. This would be great for:
1. Vehicle interiors.
2. Tracking vehicle hood-mounted shots.
3. Short, overhead tracking shots using only two stepladders and a couple C-clamps.
4. Tripod-mounted track runs (relatively short in length to avoid track flex).
5. Quick set-up, on-the-floor tracking shots that only need to run a few feet.
I know there are some monorail track systems (Losmandy?), but I think they're quite expensive. Does a product like this exist? Can someone engineer and design this system for us inexpensively?
Many times I only need a three-foot tracking shot but laying down traditional metal dolly track and wedges and cribbing would attract far too much attention. The beauty of this system would be near-instant set-up (of course, you still may need a wedge or two to level). You could lay the track on any horizontal surface and be ready to shoot . . . on a table, desk, a wall, a street curb, a staircase landing, an elevator, or other architectual or location element.
EDIT: Oh yeah, this would be only used with a high-hat and fluid head attached to the 1' x 1' board. If you needed a waist-level or higher shot, you would just mount the track on two tripods.
