in after effects i imported an avi edited in premiere. i want to change the levels for each scene since in premiere there is no such mechanism as the histogram in
AE. i am doing this by placing a key frame in the beginning and end of each scene and adjust the levels for that scene. when i adjust levels for the next scene
however (after a cut) the levels before the cut (in old scene) are also changed. shouldn't one change the levels for each scene? should this be done after the editing. i guess that this problem would be solved if one uses AE to colour correct each take separetley and then use premiere to edit afterwards but i think that you will get a feeling of the color correction required only after putting it up all together. any suggestions? 10x
