Change playback speed parameter
macgregor
I need a program or tool that allows me to change the playback speed of a video (QT or avi).
For example, i have footage shot at 23.976 and 25p. But i want to edit both in a 25p timeline, and i don´t care if the footage shot at 23.976 is speeded up, all i care is avoiding having frame blending or jump cuts.
I could use the playback rate under properties of the clip, but that doesn´t give PERFECT results.
So what i´d like is a tool like Cinema Tools for FCP that allows you to change the fps parameter without re-rendering or anything.
Did you try a playback rate of 1.04 or 1.043? If you didn't try 1.043, see if it gets you closer to perfect.
Forgive the obviously simple suggestion (I haven't tried it) but selecting "don't resample" after setting a clip to playback at faster speed doesn't help?
