Derek.Sine
What do you guys think? Check it out! Is 3D legit or all hyped up?
You can't change the distance between your eyes either; you can only change their point of convergence. So why would you need to change the distance between lenses?I'm still very distraught that you cannot change the distance between lenses (at least you can change the point of convergence apparently...)
It goes on to discuss Convergence.pg.34
Interocular and Convergence:
Photography in 3-D has two variables that must be considered in designing the shot, which will affect the way in which the audience perceives the projected image, and how physically comfortable it will be to view. The first variable, 'interocular', is the distance measured in inches between the two lens axes (or e.g., between your pupils, approx. 2 3/4 inches). Simply put, the greater the interocular distance, the greater the perceived 'depth' in the shot. Generally speaking, the closer the subject to the camera, the smaller we set the interocular. For example, a close-up shot that cut at the top of the shoulders would have its interocular set at about one inch. Long wide shots, such as an establishing exterior, might have an interocular at two or two and a half inches. Simply put, the greater the distance to the subject, the greater is the need for a wider interocular, so as to create the illusion of depth.
Sorry, I've never really looked into 3-D...Really Barry? Haha. You're breaking my heart, man.
All magnificent points. You win!You can't do many things with your eyes, that we do in cinema... such as zoom. Go through walls... see predator vision. Lol.
