century optics 0.6x wide angle lens ?
overlord
I am going to buy a wide angle lens for my DVX100A, seach the forum and get some info and clip
for example :
http://www.icexpo.com/dvx100/century.html
the 0.7X CO , is full zoom thru one ,but I still can find there is little blur around clip,and somebody said ,that 0.6 x is not zoom thru,but the blur is not found in that picture
which one is better for me ?
if you compare the original picture with picture 0.6x, you can find 0.6x PICTURE is not really sharp, does anybody think so?
is it normal?
I don't recommend the .7x. It may be zoom thru, but it doesn't retain sharpness and it has soft corners.
The .6x is about half zoom through and stays sharp. Or the 16x9 .8x is full zoom thru, but it really starts to get soft around the edges at full telephoto. Still, that's better than the Century, which gets fuzzy and soft when at full wide angle.
The .6 is cheaper than the others, and performs more predictably. And it only takes about 1/2 second to remove it if you need access to more telephoto.
