Century Follow focus.
realm.cc
Hey I was wondering if anyone has used that Century Optics Follow Focus? If so any recommendations on it? Is this a "must have" for some one that deals with movie production? thanks.
Re: Century Follow focus.
really?
i assume it really only matters if you have a carefully planned scene with marks and someone else pulling focus for you?
i have looked at it and always wonder how it could be worth so much unless you had a camera assistant and maybe if you were also working on a dolley.
i know it costs so much because of the demand/limited quantity they must produce, i just don't know how much use the average dvx user would get but i'd love to know more, maybe i'm missing something?
matthew
It also flat out puts it at a nicer, more comfortable spot, you're not contorting your hand as much while racking.
But, for the most part it's really useful because, as was said, you can get a focus puller.
AND,
Last but not least:
It looks really cool
"AND,
Last but not least:
It looks really cool "... maybe you could get yours chromed too Mike....how sad.
Matthew, you could use the FF with a puller, but you'll need a whip, monitor, and someone experienced you trust. A FF puts the focus right in you hand in a much more natural position, allowing for a much smoother camera movement, again, you have to shoot with one to truly understand as it's hard to explain properly.
[quote author=pookie link=board=Links;num=1096584986;start=0#4 date=09/30/04 at 21:52:49]"AND,
Last but not least:
[/quote]
If I end up buying one, I just might!  ;D
In the interest of clarity, for anyone who might be confused, Century manufactures a follow-focus gear with end stops to create a hard stop at infinity and close focus to make it easier to "pull focus" to pre-determined "marks". Century does not manufacture a follow-focus drive, those are the knob/gear train that attach to rods under the lens and mated to the follow-focus gear. The drives are made by Chroziel and others.
Bill Turner
Century Division
Scneider Optics
Bill,
Right now I have the Chroziel Follow Focus and I was wondering about the century optics manual focus. My post should have said
"Hey I was wondering if anyone has used that Century Optics Manual focus with the Chroziel Follow Focus? If so any recommendations on it? Is this a "must have" for some one that deals with movie production? thanks. "
thanks!
If you shoot in the 24P mode you will find that the focus ring just turns indefinately, therefore you have no external reference to where on the focus range you are. The Focus gear has a lock out position which limits the lens focus range from ~2-feet to Infinity with hard limit stops. The White Delrin Focus Scale ring can be used to make your own markings (using a dry erasable marker) making it possible to repeat a move over and over.
I hope this helps.
Robert Orlando
Century Optics
Robert,
thank you, so far that has been the hardest part about manual focus (repeating a move), i'm going to go ahead and order the Century manual focus. thanks!
I've had the century manual focus for some time and use it with and without gears. It's excellent.
ok so you guys who have the follow focus, what type of stuff are you creating with your dvx?
matthew
focus pulling is so easy to make yourself, while shooting, that i very rarely ever needed someone to pull focus for me.
on rehearsal, actors hit the marks, i remember the focus numbers as they're displayed on the LCD/Viewfinder... and that's pretty much the whole story.
if i've already had a tripod and matte box and a nice set of filters and anamorphic and a good microphone and then, even some more spare money to spend (not necessarily in this particular order), i would say why not. to me it just doesn't seem to be a necessary piece.
i guess it all comes down to whether you have "marks" to change focus for.
eventually i'll be doing a more stuff that requires that, but for now i doubt i would use it.
i would like a better focus ring.
when you buy the setup if you already have the focus ring do you get stuck with a second one or is sold in pieces?
matthew
btw.. i put a band of gaffer tape close to the focus ring (looks like its really made for that!) where i can mark stop points for focus if i need extra hands to operate a focus pull.
