Multi-Media
I needed a close up adapter and was doing a little pre-purchase research and the concurrence was that the Century Achromatic DIOPTERs were the best way to go.
Someone had reported that they had to combine BOTH the 2.0 and the 3.5 diopters together to fill the frame with a 35mm slide.
I couldn't afford to get both so my reasoning was the same with getting a Wide Angle Adapter... get the one that makes the most difference (as the camera has a pretty good range of focal length to start with)... so I got the 3.5 achromatic.
It arrived earlier today and I tried some tests on various objects... It really looks great as far as racking the focus to and fro on an object with a really narrow DOF. I then tried a simple off the boards slide transfer... and... to my surprise... I was able to more than fill the frame with a slide. It goes full top to bottom so I could even do a slight pan within the slide frame. (You will notice that the full frame newspaper and grid slides are wider than what shows in the viewfinder.)
I have a Marron Carrol optical 35mm camera with a backlit color head base and motorized copy stand post.. so I will eventually try a more professional transfer rig. But for now any backlit diffused source will do... The distance used was 8 1/2" (eight and a half inches) from the slide to the very front of the diopter.
Attached are some images from the test.
They are uploaded to the frame grab site, but I need help with linking the images to this posting.
Sorry about overloading... got it down to three now...
Jarred thanks in advance
