CCD Color Balance?
SteveO
At what color temperature are CCD's usually set so that the levels are 0,0,0 for the red, green, and blue channels, 3200K or 3400K?
Re: CCD Color Balance?
hmmm. That's a good question. All I know is that there is significantly less noise when you use an 85b filter when shooting daylight. not sure how you would set the camera to 3400k specifically though.
as 3200 is the standard, I'd expect 3200, but I don't know if the CCD has a specific "native" color temperature in terms of even voltage output.
Surely it would be better to know what the color temp was at 235,235,235 ( White) and one would assume it was as per camera setting and controlled by that setting ( or the manual W/balance).
At 0,0,0 the image is black and refers to null.
