oneinfiniteloop said:It should come with Color Finesse, which is an awesome CC tool. It comes with AE Pro on a seperate installer. Best part about it, it can work in Float point, and now that AE7 can it should produce some intersting results.
Rapier_100a said:Hey one, I have tried color finesse, but my results are never satisfactory. Do you think you could put a tutorial up for it sometime?
oneinfiniteloop said:Sure, I'm grading a music video with it now, I'll take some notes and post my workflow with some stills when I'm done.
Color finesse has some professional grade tools, but from a workflow perspective I've never been able to get into it. Firing up a seperate app from within AE seems heavy handed to me. I know what people will think of this comment, but ALL color correction can be done with the Levels tool. This is the tool of choice at many, many studios. Number one, it's easy and intuitive, number two it does anything any other tool can and number three, it renders faster than any of the other options going.oneinfiniteloop said:It should come with Color Finesse, which is an awesome CC tool. It comes with AE Pro on a seperate installer. Best part about it, it can work in Float point, and now that AE7 can it should produce some intersting results.
Now that After Effects supports 32bit the need to jump over to a seperate app to get the benefits of 32bit CC are nil. The render times of working in a 32bit comp with levels is similar to the added render time of Color Finesse, only without the inconvenience of seperate apps.Shaw said:I must disagree. Having to launch a separate application to use CF is annoying but working in 32bit floating point space is much better than the standard 8bit tools. You don't need to use anything fancy - you could just use levels in CF and the results will be better.
Levels is a useful tool but it can't do everything by a long shot. You can't adjust select segments of the spectrum nor can you increase contrast without clipping image data (as opposed to using curves).
BEENYWEENIES said:Color finesse has some professional grade tools, but from a workflow perspective I've never been able to get into it. Firing up a seperate app from within AE seems heavy handed to me. I know what people will think of this comment, but ALL color correction can be done with the Levels tool. This is the tool of choice at many, many studios. Number one, it's easy and intuitive, number two it does anything any other tool can and number three, it renders faster than any of the other options going.
I saw it used almost exclusively on Hellboy, Day After Tomorrow and a few others for the visual effects compositing work.
I know Color finesse "feels" more professional but personally I would recommend anyone interested in CC to just get real handy with Levels!
Ogrus said:what is "float"?
AndrewKramer said:Check this out. Not exactly color correction but a little insight about 32bpc
http://www.creativecow.net/articles/kramer_andrew/hdr/index.htm
Andrew
