Case for HVX rig
hvxer
Any suggestions? So far all I've seen is the stuff at Zacuto. I am looking for a case that'll fit the whole hvx+adapter+lens+mattbox rig assembled :thumbup:
You can get a large peli or storm case and fit the foam out yourself. There are companies that will take your rig and scan it in with lasers and will then cnc cut the foam for you. Im having this done for my adapter setup as soon as I can afford it.
If not, you can use pick n pluck foam or you can cut your own foam with a hot wire.
Check out Abel Cine tech at abelcine.com They have pre cut cases for Pannys. Saw one in their NYC shop last night.
Oops: Just re-read your post. The case I saw was for camera and baiscs not the adapter rig. It was not a Zacuto product that I know of. They are a Zacuto dealer but I'd check their site to see if they have anything different and their prices might be a couple of bucks lower. {you have to drop the item into the shopping cart to see the price reduction}.
