I have the Cartoni Focus HD Fluid Head.
It says that is it recommended for cameras that weigh 0-26lbs.
But, when I put my dslr camera on it, even at the lowest counterweight setting, there is still a lot of kickback.
If I want to tilt up/down all the way, the head will spring back. Maybe not to level, but definitely a few inches.
The only way I found to help with this a little is to increase the tilt drag a lot. It doesn't tilt back as much, but it still tilts. Sometimes a few mm or sometimes barely noticeable and its fine.
But, the problem is, tilting now becomes VERY heavy.
I'm using a T2i DSLR, and a 17-55mm 2.8 IS lens.
It says it should work on such small light cameras. But, I dont know what I should do...
