Thank you very much. I'm also looking for something to stack and roll my weights around (exercise weights used for jib counterweight). I've seen them in the past but don't know what they are called. It's like a two wheel dolly thing and the weights stack up on each other so it's not very large.
Not quite. In the past it seems I saw a small cart with a rod sticking up and you could stack a few weights one on top of another. It had a small footprint but was rather tallish, with a handle to pull it along. I have no idea what it is called nor can I seem to find it again.Are you thinking of a muscle cart used to move sand bags?
Well yes of course. Those are basically magliners, aren't they? I would love one of those, but I have a few issues with them (don't even mean price. . .one of those SHOULD be a one-time buy, ever): they're heavy as hell to handle by yourself, and they don't compact as well as the Rocknrollers. Also the junior sized filmtools/magliners just don't extend as far as the rocknrollers do. I really wish someone made a hybrid/compromise between the two in terms of build quality (sturdier than a rocknroller, not as heavy as a magliner) that also extended as far as the rocknrollers do (the Senior filmtools/magliner cars are as long as an extended rocknroller but are monsterous). No question the tires on the filmtools are superior. . .even when weighed down, in my experience, they almost roll themselves. Not so with a rocknroller. No flat wheels, pneumatic, doesn't matter. When weighed down they're pretty tough to push.
If you can find one of the older/90s rocknrollers used, those are actually built better than the new ones. At some point the company changed hands and build quality as well, in most folks' opinion, QC/CA from cart to cart went down. The old ones have much nicer pneumatic tires and are sturdier. Good luck finding one.
Rock n roller has some newer heavier duty carts that have bigger frames and "Low profile" wheels, but still fold-up into a fairly compact form just like the others, which is one of the biggest selling points. I bought a new one(R16 maybe?), but unfortunately the frame is so much bigger that I can't use the deck extender or the shelves with it and they have not, and make no indication that they will, make versions of these accessories for the heavy duty models. I guess I'll have to find someone to build me custom versions or modify the stock ones.
Thanks for sharing this - may try out something similar on my RnR cart. Have never liked having to put top shelf on by screwing in threaded bolts.Some people have built their own shelf mods for RnRr carts. Seems like you can make a better shelf...and one that will fit on the R16 and similar beefier RnRr carts...
