Grug
Hey guys,
I've tried searching the answer to this all over the place but can't find any solid answer to my question:
Can you capture HDV footage (i.e. footage captured to tape from an HDV camera) directly into Final Cut Pro 6 using the ProRes 422 codec? (i.e. perform the transcoding from interframe to intraframe compression when you initially capture the footage on to your computer.)
That is, can you do this to avoid having to capture your footage into FCP6 as HDV and then spend the extra time transcoding the HDV into ProRes? I know that you can capture ProRes 422 from an HDV camera using a capture card, but that's not what I'm interested in. I just want to figure out the most streamlined process for getting HDV footage into intraframe codec so that I can edit it smoothly.
Is this possible? Or do I have to capture my footage as HDV first and then transcode?
I will be using a Mac Pro for this.
