Capturing Analog video in FCE with DSR-11
Markp
Can you help?
I need to capture some Analog video into Final cut Express. I have a DSR-11 Deck and the input switch to video, I have changed the Easy Start to DV Converter but it does not see any video signal, I have done his before whith a PC using Premiere...
Any suggestions would be helpfull
cheers
Mark
Not sure in Express... in Pro there's a way to turn off deck control so it doesn't look for timecode.
Called - non-controllable device.
Not sure what the settings give you in DV Converter...
CaptM
Dub the analog to a DV tape in the DSR, then capture that tape. Then you'll also get timecode.
Noah
Thanks, yes I have chosen DV capture with Device control turned off but still nothing.
I thought of putting the video on to a DV tape but hoped that there would be another way.
Thanks for your help
Mark
Solved the problem, needed to set the DSR-11 menu for VTR set up, DV EE out set to on, and it work OK now.
Once again thanks for your help..
Mark
