slimchrisp
yes, yet another question about 24pa capturing. i spent almost all of yesterday reading every post in the fcp forum dealing with capturing 24pa, just to make sure i'm doing everything right. i've reached that point where it's almost funny that i can't get this to work the way it should.
here's my situation. i shot 24pa on a clean tape. i capture using this easy setup:
"DV NTSC Advanced (2:3:3:2) Pulldown Removal"
i delete the original sequence, and use a new sequence that is for a 23.98 timeline.
i read in a few posts that if i have to render at this point, then i am doing something wrong. woohoo! i have to render. F**K!!! my other option is to go to the tools menu, and do the "remove advanced pulldown" at that point.
seriously, this should be so easy. based on the million posts i've read here and everywhere else, i should just have to capture my footage with this setting and do the pulldown removal on the fly. then i should just need to make sure my sequence is set to 23.98, and all should be copacetic. BUT NOOOOO!!!!! i know i'm not an idiot because there are so many posts dealing with the same exact thing.
i would be happy just rendering or doing the pulldown again after my capture, but my footage still seems jumpy.
here's my other problem. i shot anamorphic squeeze mode. i tried making my own easy setting where the only thing i change is the anamorphic check box.
have to render or redo pulldown.
i try capturing without anamorphic and use the factory preset, then set to anamorphic after the capture.
look, i'm really sorry to post this yet again. i shot 24pa for the first time after reading a lot about it, and when was the right time to do it, blah blah blah. but i'm really on the verge of a nervous breakdown.
has anyone else had this happen, and finally found the magic
"no seriously, i really want to remove the pulldown during capture" checkbox?
because if you have, i'd really like to know where that is.
