Capture Video Won't Read Camera
PriceDollaz
I have a Sony DCR-HC30 and when i go to put the image on the computer it will not capture image it says preview turned off is there something i need to get or do to get rid of this problem??
Re: Capture Video Won't Read Camera
i have a digital camcoader and when i go to capture image it does not read my camera but it reads my VHS-C camera. its a sony digital camcorder and the preview says "Preview is turned off" i went to go and try to reconnect .. that does not work i have it on smart preview so it should read when i hit play in my editing mode. The Cam it sees is cirrus logic USB-DVR2 Source
How are you connecting the Sony camera to your computer, if USB that will not work must be firewire. Its funny the VidCap will see a USB web cam but not DV cam on USB
HunterG
Do you have a LAN adapter on a firewire card (check your Network Properties to see what LAN adapters there are)? If so, that could be your problem.
I don't know how to fix it, but I had the same problem with a Sony VAIO notebook. When I plugged in a PCMCIA firewire card and connected my camera (DVX100A) to it, everything worked.
I remember reading about how to fix the firewire LAN stuff in Spot's Vegas Editing Workshop, but I don't have the book with me, so I can't help... :(
oh jesus christ i am coonnecting AV - my dazzle digital video creator instead of havin firewire connecting my DV to the video card ...
where do i buy firewire ??
thanks for this and helping me see the possible light
[quote author=HunterG link=board=Vegas;num=1100134906;start=0#3 date=11/10/04 at 18:56:23]How are you connecting the Sony camera to your computer, if USB that will not work must be firewire. Its funny the VidCap will see a USB web cam but not DV cam on USB
HunterG[/quote]
When I start Vidcap, it always shows the notebook's built-in web cam first - I have to go to the menu bar and select another source to see the DV camera's image.
But when I use DVRack, I see the DV. Isn't that weird? I learned to live with it, though... it's just a couple extra clicks.
[quote author=PriceDollaz link=board=Vegas;num=1100134906;start=0#5 date=11/10/04 at 19:07:31]oh jesus christ i am coonnecting AV - my dazzle digital video creator instead of havin firewire connecting my DV to the video card ...
thanks for this and helping me see the possible light [/quote]
You can get a firewire cable at any Best Buy or Circuit City. But does that camcorder have a firewire out? Not all do, actually.
And does your computer have a firewire port? If not, you'll need a firewire card -- video cards generally do not have firewire ports.
