Capture settings w/ HVX200 into Premiere
jsstring
What is the difference between HDV and Quicktime formats when importing HVX200 files into Premiere CS4? What is higher quality?
Unlike FCP, Premiere Pro will natively handle the files as-is without any kind of transcoding.
This means there is no loss in quality when you are editing. As long as you export to a medium that is the same or higher quality you should see no loss in quality. Keep in mind that DVCProHD can have generational loss around 10+ exports.
Depending on what you convert your DVCProHD files to in FCP, that will determine if there is a quality loss. ProRes 4:2:2 should yield no quality loss, but will yield a generational loss after so many re-encodes.
After you transfer to DVD, Blu-Ray, or Streaming media there is quality loss since those are all 4:2:0 mediums and there will be a quality loss even if your bitrate is infinitely high.
