G
Guest
Guest
Hi,
I usually record to tape with my dvx100 using 24pa, but sometimes the quick setup dial was switched accidentally resulting in a different frame encoding, like 24p for example.
Everything is recorded in 29.97fps on mini-dv, we all know that, making apparently no difference b/w 24p and 24pa.
But of course, when i'm trying to capture this footage through FCP, i can't always remove the advanced pulldown because there's a few clips that have been recorded with 24p instead of 24pa.
Questions:
- How can you detect the different encoding on tape, whether it's 24p or 24pa?
- Can you get FCP to create a new clip (at least stop) the capture for those sections of the tape where I have something different than 24pa?
- If nothing like that is possible, how do you solve this problem?
Thanks!
Questions:
Thanks!
