Dizkoteck Well-known member Dec 9, 2004 #1 I got my new EXT HDD, the Lacie Porche firewire. I havent used one in a long time. But when I try capturing now through the HDD, it gets stuck there with "allocating disk space" Is there something missing? something I did or didnt do? Thanks guys
Prairieboy Veteran Dec 9, 2004 #2 Re: Capture Now on EXT HDD ::error::error::error:: Two silly questions. Did you check the cable, and have you set it as a scratch disk?
Dizkoteck Well-known member Dec 9, 2004 #3 Re: Capture Now on EXT HDD ::error::error::error:: Yep. I shouldve mention this earlier I can however batch capture fine, tad slow but fine. The cable is tight. I got screwed by Lacie didnt I?
S Scottdvx100 Veteran Dec 9, 2004 #4 Re: Capture Now on EXT HDD ::error::error::error:: Set capture now to the smallest amount you can for your capture. (i.e. 30 minutes or whatever)
Dizkoteck Well-known member Dec 9, 2004 #5 Re: Capture Now on EXT HDD ::error::error::error:: yeah its already on 30 mins. oh well, I guess I'm just screwed.Always happens to the asian people
